How hard?
Old Mar 1, 2008 | 01:49 PM
Rumplecat's Avatar
Default How hard?
How hard is it to change out the main serpentine pulley on my '97 montero? My crank bolt started to back out and in turn made the pulley warped. Can I do it or do i need to take it to the stealership or and independent shop? Any help is greatly appreciated!
Thanks,
James
Old Mar 1, 2008 | 02:56 PM
Default RE: How hard?
Its fairly easy.
Old Mar 1, 2008 | 09:50 PM
Rumplecat's Avatar
Do I have to remove anything to get to it?
Old Mar 1, 2008 | 11:38 PM
I honestly couldn't tell you, but in general they are fairly easy. Just one bolt...
Old Mar 2, 2008 | 10:48 PM
Rumplecat's Avatar
Ok thanks.
Old Mar 3, 2008 | 01:58 PM
Liquid_force's Avatar
the problem will be holding the pulley in order to torque that bolt. IIRC it requires ~130 ft-lbs.
I had to build a tool for it.
Old Mar 4, 2008 | 10:07 PM
jgbrules's Avatar
hello! if that crank bolt came loose it is possible that the threads inside the crank itsself were damaged. i would buy a tap to clean out the threads in the crank, and use a new bolt to install. be sure to use lots of thread lock on the new boltwhen you reinstall. the tourqe is 134 ft.lbs. use a large chain wrench to hold the pulley when you retourque the bolt. the dealer will have that bolt in stock, that is a common problem on the montero. whoever did the last t-belt replacement didnt tourque it correctly. good luck! greg...
mikewired
Aug 4, 2019 08:14 PM
bjoelson_gsx
Jul 9, 2005 01:12 AM
99clipsgst
Apr 25, 2005 08:41 PM
rx7reality
Oct 14, 2004 07:45 AM
snoop
Jul 6, 2004 07:41 PM
