Location of PCV valve on 3.5L V6 for 1994 Monty
Old Jun 8, 2012 | 06:13 PM
jallert's Avatar
Default Location of PCV valve on 3.5L V6 for 1994 Monty
Can't find the thing!
Pics are welcome.
thanks.
Old Jun 8, 2012 | 10:01 PM
mxmikie's Avatar
drivers side valve cover under the intake manifold 3/4 the back from the front on the inside of the valley
Old Jun 9, 2012 | 08:43 AM
jallert's Avatar
Default Intakes needs to come out?
So then I need to remove entire intake to chg the valve?
Old Jun 9, 2012 | 01:06 PM
mxmikie's Avatar
if your good you can reach it with really llllllllloooooonnnnnngggggg needle nose
Old Jun 9, 2012 | 01:08 PM
mxmikie's Avatar
or you can remove the intake ..... get your gaskets first and if you do remove the intake then you can check the butterfly valves and their shaft for vac leak and play if you need i have a center section that the butterflys have been removed and the shaft holes plugged
Old Jun 9, 2012 | 10:38 PM
mxmikie's Avatar
Akmikek
Mar 7, 2013 08:58 PM
Missile
Nov 26, 2006 10:48 PM
tiger13
Apr 13, 2006 01:31 AM
edaddik
Nov 24, 2005 02:14 AM
popatop
Dec 10, 2004 11:48 PM
