looking to buy a montero limited
I own a '01 Montero Limited. It does have C/D Lock wording on the 4x4 indicator on the dashboard. It also has the 4 position transfer case shifter: 2H, 4H (all-wheel drive), 4HL (this one is locked C/D) and 4LL (low range, locked C/D).
I believe all Montero's after '01 model had similar setup. If the transfer case has 4 positions you are getting the one with the lockable center diff as well as the all-wheel drive option.
As far as running hot, I've never experienced this with my Monty. I live in the area where we get temp from negative 15-20F in the winter to well over 100F in the late summer. The cooling system is well designed and always kept the temp in the proper operational range.
I agree that if you are getting one of the older models (01-03 years) they are likely to have an oil leak past the valve cover gaskets. This is not a big deal and a good weekend project to replace them. There can also be a leak past the cam position sensor. This one is very easy and the gasket cost is like $3. Just make sure the engine is cold when you are working on this one
I hope you find a Montero you like. I love mine and I would definitely and wholeheartedly recommend it to a friend. He just can't buy mine - I'm keeping it
Does your instrument cluster say cd lock like this one? And please if im wrong let me know cause you own one and im only gathering info to purchase. But to my understanding cd lock means diff lock and your t. Case shifter should have 2h 4h 4hlc 4llc. The 4hlc and 4llc should lock the transfer case and send a 50/50 split power to the front and rear diff. Is this not the case on the limited?
Thanks guys, I think my last questions with this setup is why is there no 4L unlocked? And how come they are not a popular wheeling machine? Having an lsd and a lockable center diff would make this thing nearly unstoppable. People should be wheeling the bread crumbs off em. Lastly does anyone have any experience with beach driving in their montero? We vacation in the obx and would need to be sure that it would take me through loose semi deep sand.
Mine was my off road machine for 8 years until i got my '87 4runner in 2010. That means my monty rarely sees any dirt anymore. I did a fare amount mud, river crossings, snow, etc. never had any problems with my truck.
Awesome! I hope to find one soon. I have been scouring craigslist to find one in the 300 mile radius, I dont mind to travel for the right vehicle. I also have my xterra up for sale on craigslist as well. Hopefully I can get out of it and into a montero. I am looking at some 01/02 but reading in msn.com those 2 specific years have moderate failures compared to 03/06 can anyone tell me what failures are specific to 01/02?
Thanks all
Thanks all
I've had both recalls preformed and have never had any issues with my '02...it has taken us many, many miles both on and off road.
The main difference with the later model Gen. III is that is has a 3.8L..
I've been looking at an 01, 03, and 04 on craigslist but they are all 150 miles away from me, and seem to good to be true. The 01 is from a used car lot and is $3999 with 114k, the 03 is a private seller $5000 with 157k, the 04 is from a used lot for $6500 with 127k. I havent looked at any 2002's because I hear they are less reliable, anybody know if this is true?
