McGard Wheel Lock
Old Sep 23, 2006 | 08:27 PM
99Montero's Avatar
Default McGard Wheel Lock
Recenly purchased my 99 Montero. I cannot get the wheel off due to a McGard wheel lock. What are my options to get a new wheel lock key? (without having to spend a ton)
Old Sep 24, 2006 | 10:09 AM
Manybrews's Avatar
Default RE: McGard Wheel Lock
go to your local dealer. have them match it up with their master kit.
then have them order you a new one.
Old Sep 25, 2006 | 03:00 AM
off roader's Avatar
I've never seen a McGard reseller with a master key set. Buying the keys from McGard will be the least expensive unless you can replace your lugs for less. What I mean is you can break off the wheel lock and replace your broken studs.
Old Sep 25, 2006 | 07:25 PM
Manybrews's Avatar
all mitsu dealers have a master kit for the McGard wheel locks that were OEM equipment. there are only 10 different locks used by mitsubishi.
our shop has 2 kits, and I purchased one myself (although thankfully those locks are becoming more and more rare).
so go to your local dealer and have them match one up.
Old Sep 25, 2006 | 11:11 PM
off roader's Avatar
ORIGINAL: Manybrews
Cool. Didn't know they started using McGard locks at the dealers. I know earlier models (Gen II and earlier?) don't have wheel locks stock.
Old Sep 25, 2006 | 11:31 PM
Manybrews's Avatar
ALL of mitsus wheel locks have always been made by McGard, even though they probably arent marked as such.
starting with the 92 model year, I believe.
the only car in the mitsu lineup not to use one of the 10 mitsu/McGard locks is the new Raider, which does use McGard locks, but a chrysler type.
Old Sep 26, 2006 | 06:41 AM
off roader's Avatar
ORIGINAL: Manybrews
Interesting. My Gen I's both came with a wheel lock for the spare that used the ignition key.[sm=shades.gif]
As for locks on your wheels/tires, unless you live in a really bad area and/or have either racing (OZ, BBS, Fitipaldi, etc.) or total "bling" rims, then I doubt you'd need them but I guess its better to be safe than sorry. I also obviously a pain in the you know what when you loose that key.
Old Sep 26, 2006 | 05:36 PM
Winshawn's Avatar
Just take a cold chisel and hold it at an angle, tap lightly a couple times and the lock will unscrew nicely. It is hard to describe how to hold the chisel with words. Just angle it in a way that would unscrew the nut. However, this will destroy the wheel lock. Wheel locks are useless. They provide zero added protection to your wheels.
yzrider22k
Oct 8, 2011 07:38 PM
mchang40
Jul 13, 2010 08:12 PM
puwit321
Sep 5, 2008 03:42 PM
vixx
Jun 5, 2006 08:38 PM
