mitsubishi montero limited transmission overhaul kit from dealer
Old Oct 9, 2013 | 05:55 PM
navidbe's Avatar
Default mitsubishi montero limited transmission overhaul kit from dealer
i went to the dealer 2 weeks ago and i told them that my tranny has blown and i need to rebuild it.
they showed me an overhaul kit that was for sale for $500.00 and it seemed like a good deal.
in the picture it showed a huge range of gears and gaskets in it.
i asked the guy working there that does it come with the reverse gear and all the other gears and he was stumped.
does anyone know what it comes with..
the car gear does not move and the reverse is completely 100% gone, and it also starts off in limp mode. if that helps anyone understand my situation.
Old Oct 9, 2013 | 10:48 PM
Akzle's Avatar
id be surprised if you got a full pinion set for 500$.
Id be more surprised if you actually managed to rebuild your trans.
Old Oct 10, 2013 | 12:37 PM
navidbe's Avatar
what do you mean you would be surprised if i could rebuild it??
Old Oct 10, 2013 | 02:55 PM
Akzle's Avatar
do you do it for a living?
Do you have any idea how many small spinny bits are in a gearbox?
Old Oct 11, 2013 | 01:53 AM
navidbe's Avatar
well im mechanically inclined and my brother in law is a mechanic.
lol i did not know that there was a lot of small parts in there.
this would be the biggest project that we have taken on.
i cant find any used trannys and everywhere i go, mechanics are trying to charge me 3 to 5 thousand dollars for it which makes no sense.
Old Oct 11, 2013 | 02:18 AM
Akzle's Avatar
its entirely doable. If you have a few days off work and lots of patience.
Id say you need to be more than 'mechanically inclined' to rebuild a gearbox.
By all means, go for it.
I think youll find the 'rebuild kit' is some oil seals, gaskets, maybe a few sensors. Again. I highly doubt youd get a pinion set for 5 hundy.
Old Oct 17, 2013 | 03:04 PM
navidbe's Avatar
Mitsubishi Parts - Mitsubishi Parts | OEM Mitsubishi Parts | Genuine Mitsubishi Parts
this is the overhaul kit
the part number is 2969A065
can someone please tell me what this comes with???
Old Oct 24, 2013 | 05:54 PM
Mr. Z.'s Avatar
Since you tried to get the information from the parts department at the dealer and he was of no help, have you tried calling anyone that sells OEM parts on-line. I've found that the reps. for these companies are often very knowledgeable and helpful. Perhaps they can help you.
Old Oct 25, 2013 | 03:02 AM
Akzle's Avatar
Part Name SEAL KIT,A/T OVER
cruzvillanueva
May 15, 2014 03:58 AM
monterond95
Jan 10, 2012 08:43 PM
armyeclipse
Oct 29, 2007 11:23 AM
jayv01
Jan 25, 2005 05:01 PM
jayv01
Jan 23, 2005 09:39 PM
