Montero ABS issues
Recently, the left front spindle/wheel bearing failed on my 2001 Montero ltd. As I was 500 miles from home, I was at the mercy of a local, unknown shop.
They replaced the spindle, but have left me with an abs issue. When I first start the car, the brakes violently catch and release, making it necessary for me to pump them for control. after a short bit of time, the abs light comes on and the brakes work smoothly, albeit with no ABS.
Any hints regarding what is happening?
Thanks
Thanks
No direct experience in this area but it sounds pretty likely that they messed up the wheel speed sensor when replacing your bearing - or forgot to reinstall it. I'd do a visual inspection of the mounting and wiring and pull it out to make sure it's not broken or blocked. If nothing is obvious then have a dealer pull the ABS error codes.
Ron
Ron
leejm12
Jul 27, 2013 05:57 PM
shirell
Jul 22, 2010 03:05 PM
sahmed
Dec 2, 2008 10:51 AM
jayk2k3
Dec 28, 2006 08:26 PM
