Montero ABS issues
Old Apr 6, 2010 | 06:06 AM
lovinmrv's Avatar
Default Montero ABS issues
Recently, the left front spindle/wheel bearing failed on my 2001 Montero ltd. As I was 500 miles from home, I was at the mercy of a local, unknown shop.
They replaced the spindle, but have left me with an abs issue. When I first start the car, the brakes violently catch and release, making it necessary for me to pump them for control. after a short bit of time, the abs light comes on and the brakes work smoothly, albeit with no ABS.
Any hints regarding what is happening?
Thanks
Old Apr 6, 2010 | 08:44 AM
jrmdir's Avatar
No direct experience in this area but it sounds pretty likely that they messed up the wheel speed sensor when replacing your bearing - or forgot to reinstall it. I'd do a visual inspection of the mounting and wiring and pull it out to make sure it's not broken or blocked. If nothing is obvious then have a dealer pull the ABS error codes.
Ron
Old Apr 7, 2010 | 04:51 AM
lovinmrv's Avatar
Thanks, Ron. I'll check it out.
leejm12
Jul 27, 2013 05:57 PM
shirell
Jul 22, 2010 03:05 PM
sahmed
Dec 2, 2008 10:51 AM
jayk2k3
Dec 28, 2006 08:26 PM
fallingapart3000gt
May 13, 2006 01:35 PM
