Montero Ltd auto won’t shift out of neutral
Old 10-06-2017, 08:42 PM
Kbinger's Avatar
Default 01 Montero Ltd auto won’t shift out of neutral
When backing up I pulled the shift to drive but it stopped in neutral and won’t move from that position. Any ideas what would cause it to freeze in neutral?
Old 10-06-2017, 10:45 PM
Will it go back into Reverse? First thing to check if linkage or brake interlock is OK or if something disconnected.
Old 10-07-2017, 10:34 PM
Kbinger's Avatar
It won’t shift out of neutral. The linkage and shift cable are good
Old 10-07-2017, 10:35 PM
Kbinger's Avatar
It’s a 2001Montero Ltd
Old 10-08-2017, 12:49 AM
Do you have any lights flashing on the dashboard?
Old 10-09-2017, 08:07 PM
Kbinger's Avatar
Default Antilock and 4wd light flashing
The center 4wd light flashes 3 longs and 4shorts
Antilock flashes 2longs and 4shorts
1 long and 2 shorts
3 longs and 2 shorts
2 longs and 4 shorts
1 long and 5 shorts
2 longs and 1 short
2 longs and 3 shorts
Old 10-09-2017, 10:36 PM
Transfer ECU error 34 - Free-wheel engage solenoid system fault.
Likely causes: free-wheel solenoid failure, damaged harness to free-wheel solenoid
1 long and 2 shorts
1 long and 5 shorts
2 longs and 1 short
I can't find Montero specific ABS fault codes, but for a Mitsubishi Evo these codes indicate fault with nearly all four ABS sensors. With this many codes most likely issue is the harness damage (disconnect) or ABS control module malfunction.
Since your original concern was no shift out of Neutral - Does the Neutral light on the dashboard flash at all?
Old 10-10-2017, 10:05 PM
Kbinger's Avatar
1 long and 2 shorts
1 long and 5 shorts
2 longs and 1 short
No flashing neutral light
WA_2002 Montero Limited
02-12-2020 01:57 PM
newoutlanderfan
03-19-2014 01:18 PM
Calijim
01-17-2013 04:35 AM
Ms.Fixit
09-23-2010 10:55 AM
Ms.Fixit
09-12-2010 01:43 PM
Quick Reply: Montero Ltd auto won’t shift out of neutral
