montero sport 99 recently started idling too fast when it's in park - HELP!
Old Nov 29, 2007 | 11:50 PM
ac777's Avatar
Default montero sport 99 recently started idling too fast when it's in park - HELP!
my montero sport 99 recently started idling too fast when it's in park or stopped at a light. RPM's are around 1000 and revs a few notches above and then goes down. i can hear the reving of the engine. the start of a problem? also, anyone know a good Mitsubishi repair shop in denver, co? i'm on a fixed income and need to know who i can trust.[&:]
Old Dec 1, 2007 | 11:43 AM
xyzik's Avatar
Default RE: montero sport 99 recently started idling too fast when it's in park - HELP!
when an car starts idling fast it may have a vaccum leak somewhere, I'd start at the brake booster, the hose that connects from brake booster to engine. looking for a vacuum leak is a drag, but a logical approach will help like making a list of what vac hoses youve checked so you dont go over it again and again.
also check, out the EGR, air filter and PCV they might need changing
hope this helps
Old Dec 1, 2007 | 01:13 PM
carlover626's Avatar
As far asa repair shop...I am in Denver myself, but I haven't ventured away from the dealer (Quality Mitsubishi on S. Broadway is my pick) since I am still under an aftermarketwarranty till 101K.
If you hear of something cheaper than the dealer you should share!
A good way to check for vac leaks: (with the engine running) carefully take a can of starting fluid and spray a little on the vac lines...if the idle changes you found the leak.Be carefuldoing thissince theengine has to be running.
Old Dec 1, 2007 | 07:41 PM
dsm1990gsx's Avatar
Pretty much what carlover626 said spray a can of starter fluid and listen to the engine rpm's change. Thats the best and easiest way to find a vacuum leak.
Old Dec 3, 2007 | 10:00 PM
ac777's Avatar
thanks so much for the responses! i will try what was suggested and report back. also if i locate a good repair shop........
Old Dec 5, 2007 | 04:25 AM
crow's Avatar
It could also be the ISC servo, my 99 sporthad the same problem idle goes high then low and to ap point where it stalls. changed servo then it is fine.
Neco
Jun 26, 2012 09:38 AM
SlavinAMP
May 16, 2009 08:10 PM
foxyguy76
Sep 26, 2008 11:59 AM
locoal619
Feb 6, 2007 11:52 PM
