montero sport gas can
Old Aug 9, 2007 | 05:00 PM
Moulon's Avatar
Default montero sport gas can
What is the best way to secure gas cans on Montero Sports? Im thinking of just chaining 2 or three to the roofrack[>:]
Old Aug 9, 2007 | 06:58 PM
off roader's Avatar
Default RE: montero sport gas can
Use tie down straps. Also if you're talking about 5 gallon gas cans with a screw on top made by Blitz, I've found they don't seal properly and as a result gasoline can leak out. When I tried one trip from California To Utah, with my 90 Montero's the gas dripped out of the can, down the roof and some went into the rear vents resulting in gas fumes in the passenger area.
The gas can's that I use now are the military Gerry cans which utilizes a cam door mechanism. It seals much more securely. You can put one inside you're rig and not have an issue with fumes.
Old Aug 26, 2007 | 04:43 AM
mxmikie's Avatar
build a rack or make a really cool holder ................. sounds better than a fire ball
Old Aug 31, 2007 | 01:39 PM
jpmontero98's Avatar
custom make somthin out of steele and rivotswith those straps and put them on the back of ur monty
EVOIXGUY
May 14, 2013 05:07 PM
Nastyben1
May 13, 2012 03:29 PM
chevegan
Oct 6, 2010 03:52 PM
wmlove3
Aug 9, 2010 10:53 AM
JJT
Mar 23, 2007 03:13 PM
