montero sport help
Old Sep 15, 2008 | 09:36 PM
dodge_ss/t's Avatar
Default montero sport help
Hello, new guy posting for a friend who just bought a 98 Montero sport 2wd auto. We have big plans for the car but have a couple problems that need to be fixed before we can start the murdering out, all black inside and out with a bad a$$ system.
When the radio is on we can not get any reception, The antenna dose not come up at all. The radio head unit is aftermarket but i do not recall the make. Any ideas as to why he can not get any radio reception? We only heer static and cd's play fine.
And last, this one might be a little harder to diagnose, but when exhilarating from a dead stop the motor sputters until and i quote "you push the peddle down to a certain point"then its normal.I will pull the plugs this weekend to see if there bad but im thinking that its a little more advanced of a problem then just bad plugs. We were also told that it needed a new catalytic converter from who he got the car from but it is there and not gutted so im thinking its clogged.
Thanks, as a dodge/chevy guy im kind of lost. lol[/align]
Old Sep 15, 2008 | 09:57 PM
MonteroMan's Avatar
Default RE: montero sport help
im the owner of the 98' 2wd he's talking about. were changing out the catalytic converter, but theres a prob with the acceleration. within the first 5mph theres a bit of lag, and once you've past it, it goes away.
we got big plans for the monty and in order to make the plans happen, we need these opsticles out of the way.
-thanks
Old Oct 1, 2008 | 07:04 AM
maisvanoyan's Avatar
2000 MMS - the horn is not running on the certain positions.
Instead a click is heard while pushing on steer and no beep.Probably relay is clicking.
Besides, no beep while pushing on the remote "lock". Is it matter of dissamblage of the steer, or maybeI have to do simpler job?
Thanks in advance.
Old Oct 1, 2008 | 02:45 PM
MonteroMan's Avatar
im sorry buddy. mine works great so i havent had the pain in the A$$ to play with a messed up one, or i'd have some info for you : (
Old Oct 2, 2008 | 03:01 AM
Thanks to MonteroMan for the answer. I hope to hear soon.
Old Oct 2, 2008 | 05:34 PM
carlover626's Avatar
Those plugs are a job the first time around (still haven't done mine @103K, they probably have been done by the PO but not sure) I recommend looking at this: http://www.monterosportonline.com/diy-perf2.html.
How many miles are on the MS?? FYI the timing belt is something that should be done every 60K,the MSan interference motor and will cause much damage if it snaps, even at idle. I believe the plugs in the 3.0L are iridium (IIRC the interval is 60K miles).
Oh, and another good place for Montero Sport assitance is www.4x4wire.com.
lemmontero
Apr 28, 2010 11:33 AM
redturboeclipse
Dec 14, 2009 11:10 AM
autoseattle
May 10, 2007 06:17 PM
DarkManC
Apr 15, 2006 01:33 AM
fwank01
Mar 9, 2006 11:12 PM
