Montero Sport Lx P0705 Code
Old May 6, 2012 | 01:49 AM
johnnycz's Avatar
Default Montero Sport Lx P0705 Code
I'm getting a P0705 code after changing Cigarette fuse. Everything was working before changing the fuse. Now the transmission only works in 3rd. gear and reverse. No transmission indicator lights work, and check engine light is on, also SRS light is on. No backup lights also. Trans. system seems completely dead. The manual says Trans. fuse is in the under dash fuse box. The location for the fuse is empty , no contacts or fuse? The fuse box cover indicates that it was there. Where is the fuse or fusible link located now? I can't believe it can be a sensor since it was working minutes before. The cigarette sockets still don't work. I have checked all fuses and fusible links I could find, All are OK. I have no wiring diagram or component locations. All connections to transmission seem good. But how to check power locations, or troubleshoot trans. control system. I don't even know where the system components are except for trans. Like I said it seems the system is not getting power. Please help!
Old Jul 14, 2017 | 01:22 AM
asac55's Avatar
I have similar issue with my truck. I am not really sure what to do. I have the code P0705. I replaced the range sensor on the tranny already. I will look at fuses and adjust the shifter cable next. Any other advise is highly appreciated.
Old Aug 23, 2023 | 11:06 AM
iluvmymiss's Avatar
Spoiler
1998Monty
Sep 5, 2013 09:31 PM
Vaggelis
Aug 25, 2008 08:54 PM
Maverick07eclipse
Dec 13, 2007 07:44 AM
Crich4
Apr 3, 2006 08:01 PM
kuli
Nov 22, 2005 11:14 AM
