need help on rear brakes !!!
Old Jun 19, 2005 | 02:37 PM
minhvo72's Avatar
Default need help on rear brakes !!!
got the 3 clips removed for the ds rear brake..however, how do i get the 2 rods/ that hold the pads in place out ??? so i can pull the old brake pads out and slide in the new ones ?? do i need to remove the caliper from the rotor ? or is it like a Toy Landcruiser, remove clips, anti squeal shims, pins and viola put new pads in ??? s
Old Jun 19, 2005 | 06:46 PM
pc's Avatar
pc
Default RE: need help on rear brakes !!!
What model and year? Do you have anti-lock?
Old Jun 19, 2005 | 08:21 PM
minhvo72's Avatar
its a 99 Montero Sport XLS...the two rods holding the pads together...guess i have to hammer/drive it out and the rod/pin should slide out ? therefore allowing me to drop in the new pads ?
Old Jun 19, 2005 | 08:30 PM
pc's Avatar
pc
Don't you mean the pins holding the two halves of the calipers together?
Old Jun 19, 2005 | 08:33 PM
minhvo72's Avatar
yes those pins ! how do i remove them ? hammer them out with a punch/chisel ..any detailed info would help
Old Jun 20, 2005 | 09:33 AM
pc's Avatar
pc
The pins are threaded into one side the calipers. You need to remove the caliper and the two halves should be able to be separated with the pins still threaded into one side. Why do you want to remove pins?
msport_2_outlander
Jan 9, 2015 07:30 AM
unimaginable06
1st Generation
Jan 22, 2006 10:10 AM
BigMoody1
Jan 18, 2006 10:27 AM
cougar8000
Oct 12, 2005 12:34 PM
theduke1959
Jan 16, 2005 11:41 AM
