New Battery but No Power
Old Dec 29, 2015 | 04:52 PM
MurphyLimited01's Avatar
Default New Battery but No Power
I have an 2001 Montero Limited with a 3.5L. It's been sitting for a few months due to Transmission issues but now not getting power to even start it. I tried charging the battery with no luck. Took battery to get check out and they just replaced it but still nothing no lights anything. Tried jumping wires to relay box and engine turns over. How do I get to the main wires that feed the Relay box? What else to try?
Old Dec 29, 2015 | 09:54 PM
Guyfromhe's Avatar
There's probably a main fuse under the hood, check that first.
Then you need to check your ground from your battery to your block/body.
Then you should confirm you have a good positive connection on the positive side as well.
You may need to do a voltage drop test to confirm the cables are still OK.
Old Jan 7, 2016 | 01:08 PM
Going to see which one is the main. is there tool needed to remove these I've tried to pull them with my fingers but I'm afraid to use anything else or I might break it.
Old Jan 7, 2016 | 04:11 PM
Guyfromhe's Avatar
There should be a diagram on the box that says what fuse is what...
They should also have numbers on them this one will be the highest... Sometimes fuses can be tough to get out.. You may need to use pliers to remove it, just don't go ape on it.
There are also fusible links that could have got fried if everything else is good.
Old Jan 11, 2016 | 04:53 PM
Well I guess I went ape on it because I didn't know it was a bolt in type. The ones in the Relay box you could tell for sure but the one that attached to the battery is the one in question. So picking up a new one tonight however I don't see anywhere to open the box to get to the bolts. Any Idea's.
Old Jan 13, 2016 | 06:09 PM
Robert A. Watson's Avatar
If all else fails, check the wiring harness on the firewall side of the engine; exhaust side... the wires tend to melt together causing all kinds of electrical issues.
gnevah
May 1, 2025 04:29 AM
waid302
May 8, 2021 01:14 AM
Jmwatson14
Jan 13, 2016 06:14 PM
Roshid
Oct 11, 2015 08:05 PM
corsair_105
Oct 19, 2013 10:27 PM
