Newbie engine dead? please help/advice
Old Aug 20, 2013 | 10:01 PM
Ninjobitch's Avatar
Default Newbie engine dead? please help/advice
Hey everybody new to the forum I have a huge problem with my02 limited my radiator went belly up a few months back I ordered a new one from Mitsubishi ($700 f$$&&ing dollars) had it installed and after a month the entire bottom seal blew on it at 4 am in the middle of my 30 mile mountain drive to work and I had to walk for 5 miles because there is no service... Anyway radiator is warrantied so no worries there my problem is is drained all coolest so fast and I had no water that I think engine got to hot now engine won't turn over starter sounds like its working but when you turn key you get a whirring sound but no catch or even a cough from the engine did the motor seize from the heat WTF please help
Thanks
Old Aug 20, 2013 | 10:08 PM
If the starter is turning, then the engine isn't ceased. The starter is failing to make contact with the flywheel for one reason or another. Either the flywheel is missing teeth, the starter is loose, or some other reason.
Old Aug 20, 2013 | 11:31 PM
Ninjobitch's Avatar
Ok thanks a place to start finally I've had emotional issues with my Montero and been pretending it wasn't broke because I wasn't sure where to start. Will check to see why contact isn't being made thank you very much
Old Aug 21, 2013 | 12:35 AM
You're welcome, good luck.
SkydiverFL
Sep 7, 2013 09:36 AM
KF97diamonte
May 5, 2010 01:38 PM
zmarcoz
Mar 27, 2008 05:00 PM
HiZ
Jun 4, 2006 07:23 PM
vertigo14k
Sep 18, 2005 11:55 AM
