No Fire
Old Feb 23, 2018 | 05:36 PM
2001Mitch3.5XS's Avatar
Default No Fire
Ok guys, I have 30 lb. of fuel on the fuel rail.. starts only with starting fluid.... I have 12 volts constant for the fuel injectors.. ?????????????????????????????????????????????????? ???????????????? Computer is new.. Injectors are new.... Puzzled....
Old Feb 25, 2018 | 04:31 PM
12v constant on fuel injectors is the issue. You suppose to have square wave signal on injectors. I can't confirm is it should be 5v or 12v though. Are you 100% certain that PCM is the right one for your engine?
Old Feb 25, 2018 | 04:32 PM
Just for kicks - connect old PCM with new injectors and see what happens.
Old Feb 26, 2018 | 05:16 PM
Tried the old pcm and put a new pcm on it with the same issue... if i put a stethoscope on it you can hear the click that the injectors are opening and with 30 lb. on the fuel rail I am totally stumped.. I checked the schismatics on it and it should have 12 volts all the time and the negative side goes to the pcm...I D K... Thanks for any input....
Old Feb 26, 2018 | 07:44 PM
Fuel pressure might be too low. On a 3.5l engine the spec is 47-50 PSI at idle
Old Mar 15, 2018 | 05:43 AM
Not even a sputter... I can hear the injectors open with the steth but to no avail...
Old Mar 15, 2018 | 04:09 PM
Next two items to check is spark and compression.
maclawa
Apr 20, 2007 06:11 PM
antomx
Feb 18, 2006 09:53 AM
Atownprepy99
Aug 15, 2005 12:28 AM
STACYYY23
Jan 18, 2005 10:23 PM
fmart
Dec 22, 2003 02:12 PM
