Noise for front drivers side wheel well
Old Aug 21, 2014 | 10:13 AM
PittsburghMontero's Avatar
Smile Noise for front drivers side wheel well
Well I'm getting a "warbling" noise from the front wheel well. It only happens when I'm moving and the wheels are turned slightly to the left. Slow or Fast. I Check the brakes, grease the ball joints...
It's sort of like a "whomp whomp whomp" Sound
Any ideas??
I sincerely apologize if this post is vague! I have no other idea as to how to explain this problem. Plus I'm only a rookie with self-maintenance so be easy on me.
Old Aug 21, 2014 | 07:19 PM
Akzle's Avatar
check the cv joint. Could also be warped hubs, rotors or bearings.
Old Aug 23, 2014 | 01:12 AM
Two things come to mind - worn out wheel hub bearing or bad CV joint. Does the noise get worse or changes when you take a left turn at or is it mostly when you drive straight?
Old Aug 23, 2014 | 05:50 AM
no noise at all when driving straight only when turning left...
Old Aug 25, 2014 | 02:16 AM
Then it is likely to be a bad CV joint. What I don't know if noise while turning left means it is the left CV or the right one. Anyone out there knows better?
Old Aug 25, 2014 | 05:24 AM
if that's it I would assume its the drivers side... there is no noise coming from the passenger side... I'm going to check it out this week, I'll let you know. Thanks
Old Aug 25, 2014 | 12:47 PM
It will probably be best to swap the entire driver side axle. While you taking it out you will be able to see the back of the wheel hub and examine the bearing to see if that needs replacement.
alim
Sep 4, 2014 08:02 PM
PappiDread6
Nov 24, 2008 08:31 AM
missmegan
Nov 19, 2008 07:51 AM
4never
Apr 10, 2008 08:19 AM
2nd g eclipse gst
Mar 26, 2008 11:28 AM
