O2 Sensor Removal Tips
Old Mar 29, 2013 | 11:56 AM
Southern Cross's Avatar
Default O2 Sensor Removal Tips
After I read all posts I started replacing O2 sensors for the first time on 2003 Motero Limited.
According to dianostic codes, I have bad sensors on Bank 1. I got OEM parts and identified the locations on driver side (US). Knowing the condition (heat, rust, age), I sprayed penetrating solvent and left them over night. I got a removal tool (generic 7/8" = 22 mm) , warmed up a little, and ready to work on them. But they do not turn. I stopped before damaging the nut. The tool seems to be a little loose on the sensor.
Am I missing something? Any tips? I know it is not easy to reach these sensors. Should I remove something before work on them?
I really cannot afford $1,800 quoted by my dealership.
Any advice would be appreciated. Thank you in advance.
Old Mar 31, 2013 | 10:40 PM
xRx's Avatar
xRx
Soak it again for 15 mins at least and use a breaker bar ( length 17 -24 inch). I had problem with seized bolts of front brake calipers. I used penetrating oil and a breaker bar. You may want to one with a ratcheting head. Dealers will use a powerful tool called impact wrench for the job.
Old Apr 16, 2013 | 10:17 PM
I tried all those. Impact Wrench?? It will not reach O2 sensors unless exhaust manifold is removed from the engine.
mlahrens
Jan 29, 2016 06:54 AM
Maximus99
Feb 16, 2007 01:41 AM
blamesociety
Dec 15, 2006 11:28 AM
RancidSam
Nov 12, 2004 08:57 PM
coblitas
Aug 31, 2004 02:39 AM
