oil leak under exhaust manifold
hey guys figured out the grinding bit, but im leaking oil under the passenger side exhaust manifold. do i just need to pop it off and change the seal or is something that requires a lot more work? i dont mind pulling things off to get to seals, but i just wanted to know if anyone might have had the same problem and possibly know where the leak could be coming from. i thought i was just using a lot of oil, but turns out when i crawled under and pulled the skid plate off it was full of oil! please help i dont want to get screwed at the shop! thanks again! I love this forum
Look on the passenger side head on the back of the engine there is a football looking plug take the two bolts out and replace the O-Ring what happens is the air movement under and around the engine makes it look like it coming from the top of the engine hope this helps.
wait...what?
If I were you, I wouldn't take this truck on a long trip until that is fixed. Not to be a buzzkill, but it sounds like you bought a lemon, Phenoyz.
That's a much bigger job than the timing belt, and it's 95% labor.
However, mine is burning oil, as the valve guide seals are shot, so I believe. The smell produced from the smoke is definitely burning oil, and I need to top the oil up by 1/2 to 1 quart every few thousand miles. Coolant does not need topping up.
I own a 95 LS as well. It only has 89,000 miles on it. I must say, it has NEVER let me down in the 5 years I have owned it, and it goes like hell in the snow. I just don't have the facilities to replace the seals.
