oil leak under exhaust manifold
Old Oct 15, 2010 | 03:03 PM
wrkrbee's Avatar
Default 01 Montero Sport Oil leak
Originally Posted by sloopjoshc
hey guys figured out the grinding bit, but im leaking oil under the passenger side exhaust manifold. do i just need to pop it off and change the seal or is something that requires a lot more work? i dont mind pulling things off to get to seals, but i just wanted to know if anyone might have had the same problem and possibly know where the leak could be coming from. i thought i was just using a lot of oil, but turns out when i crawled under and pulled the skid plate off it was full of oil! please help i dont want to get screwed at the shop! thanks again! I love this forum
Had this same problem as well as oil on the alternator. Replaced the passenger side valve cover gasket, the rear cam seals on passenger and driver, and still get oil on the alternator as if the oil is coming from the front of the engine somewhere. Before I changed the rear cam seals, I was reading and found a post about a front cam seal which is changed when the timing belt is done.
I have not done the timing belt yet, but do have the service manual and it does not mention the replacement of a front cam seal. However, I did find in the manual how to do this.
ccernst
Jan 14, 2011 08:38 AM
TheRock0720
Nov 12, 2010 12:30 PM
pratzert
13
Aug 10, 2010 02:41 PM
q7suited
Aug 12, 2008 05:48 PM
elecbluegst
Feb 9, 2006 03:57 PM
