Overdrive not working
Hello, everyone.
I have a 97 Montero Sport. I love this vehicle. I am having issues with the overdrive. If I press the OD switch, I can see in the instrument panel the OD indicator turns ON/OFF. I know if the indicator is not lid, the OD is ON. if the indicator is lid "OD Off" it is obviously off. However, when the OD is active the OD never engage. Today I tried to keep the switch pressed, and... surprise!... the OD engage, but only while I keep the switch pressed. So, if the OD switch were bad, then the indicator in the instrument panel would not turn ON/OFF when I pressed it.... or.... it doesn't necessarily is the case.? Any advice will be appreciated. Thanks in advance!
2000MontyLtd
May 7, 2011 10:26 PM
