Overdrive not working
Old Oct 4, 2023 | 07:40 PM
Montero84's Avatar
Default Overdrive not working
Hello, everyone.
I have a 97 Montero Sport. I love this vehicle. I am having issues with the overdrive. If I press the OD switch, I can see in the instrument panel the OD indicator turns ON/OFF. I know if the indicator is not lid, the OD is ON. if the indicator is lid "OD Off" it is obviously off. However, when the OD is active the OD never engage. Today I tried to keep the switch pressed, and... surprise!... the OD engage, but only while I keep the switch pressed. So, if the OD switch were bad, then the indicator in the instrument panel would not turn ON/OFF when I pressed it.... or.... it doesn't necessarily is the case.? Any advice will be appreciated. Thanks in advance!
Old Oct 9, 2023 | 09:25 AM
unpolire's Avatar
Disassembly and cleaning the switch with electronic contact cleaner may solve the issue. If not, it's obvious you'll need to change that OD switch.
2000MontyLtd
May 7, 2011 10:26 PM
newmonty
Jul 1, 2009 10:11 PM
michael49
1st Generation
Mar 23, 2007 03:07 PM
whooliopreludee
Aug 17, 2006 01:15 PM
whooliopreludee
Aug 17, 2006 03:18 AM
