Oxygen sensor question here?
Old Jan 24, 2006 | 02:15 AM
majordomo's Avatar
Default Oxygen sensor question here?
This is the second year in a row that I need to replace my Oxygen sensor. I have a 2001 Mits Montero Limited. And it cost me $500 a pop. Is there anyone here know how to replace it or a link (site) where I could read more about it and maybe I can do it myself. HELP!!! Currently, my "service engine soon" light is on and its been lit up for 5 days now. Usually, it reset itself after the 2nd day. It goes back on again if I drive more that 100 miles in one trip. Any suggestions out there???
Old Jan 24, 2006 | 09:17 PM
off roader's Avatar
Default RE: Oxygen sensor question here?
Maybe something else is wrong and your O2 sensor going bad is just the effect of your problem?
Old Jan 27, 2006 | 03:10 PM
FireDoc's Avatar
A common problem on our model (mine is a 2002) is that the rear cam seals are crap and they leak right on your o2 sensor messing it up. next time you replace the sensor, have them do this because it won't cost much more.
Old Jan 27, 2006 | 11:47 PM
Joel_CA's Avatar
Unfortunately, there's a TSB that requires a PCM reflash AND the replacement of ALL 4 02 Sensors on the vehicle (requiring a specific DTC). It would be best if you had this done all in one shot. There's a chance that whomever is servicing your vehicle may not know about this TSB and is just replacing them as each check engine light appears.
Joel, CA
Old Apr 19, 2006 | 10:59 PM
zadam123's Avatar
I have a 2001 linited and bought an O2 sensor its part # md369190, does anyone know where this is located and how to install it?
had a code of PO 155 B2 S1 Heated oxygen sensor
Old Apr 19, 2006 | 11:08 PM
michaeljr5's Avatar
I am having the same problem. I've learned to ignore it. When I have to take the truck in for inspection I reset the computer. I know this doen't help and I hope some one knows how to fix this, I just wanted you to know you are not alone. [sm=smiley20.gif]
WOW! 5 posts while I was typing my one. [sm=jawdrop.gif]
Old Apr 19, 2006 | 11:11 PM
michaeljr5's Avatar
ORIGINAL: Joel_CA
Joel, CA
Wish I could get it into the Dealer for some work, but the nearest Mitsu dealer to me is 400 + miles away.
Old Apr 20, 2006 | 01:24 AM
Joel_CA's Avatar
The TSB i was referring to only involved the Montero- NOT the Montero Sport. It only involves certain model years as well which i believe is the introductory 2001 models.
Joel, CA
Old Apr 20, 2006 | 01:28 PM
michaeljr5's Avatar
ORIGINAL: Joel_CA
Joel, CA
Oh, my bad... [&:] I guess I need to read a little better... I'm so embarassed.
mrbo
Jan 4, 2015 09:52 AM
mrbo
Nov 28, 2014 01:07 PM
puwit321
Sep 30, 2014 12:10 PM
struculeus
Jan 30, 2009 06:07 PM
Crispious
Jul 23, 2005 09:11 PM
