P0401 EGR Solenoid 2002 Montero Limited
Thanks to Hunter D! If you have a P0401 code and determine that the solenoid is bad, needing replacement, absolutely use an OEM part. OEM does not necessarily mean dealership, I was able to find one on ebay for $40ish.
I had previously replaced mine with an auto store part and it cured the code but only temporarily. Yes, on a subsequent test it cycled on application of 12v but according to Hunter D, the solenoid cycles at a high rate and it appears that the generic parts may not be able to keep up the pace.
I replaced mine with OEM and it now cleared the code and some related codes.
Note, the mounting bracket has 3 10mm bolts, two easily accessible from the top and one that is impossible. If you remove the top 2 bolts and carefully bend the bracket back to access the solenoid mounting bolt you can save a headache. Then bend it back and remount the 2 bolts. It's your decision to try this bending method, no guarantee that it won't snap but it worked enough for me to get a ratcheting closed-head wrench on the mounting bolt and made the total job about 15 minutes.
Good luck.
Good luck.
Thanks for the kind words. I will re-iterate - If you need to get going in a hurry (passing an emmissions, etc.) and do not have OEM solenoid, you CAN throw in an aftermarket. However, if you do - order an OEM at the same time (or very soon after) and have it in on hand to be ready to swap when eventually the cheap one will fail.
coder562
11
Aug 13, 2017 08:41 PM
David Temple
Oct 29, 2016 09:56 PM
