pajero super select 4wd indications
To the best of my knowledge, when in 2wd just the rear wheel lights should be on, in 4h, the 4 green lights will be on, then once you get to 4 hlc or 4llc the orange centre differential locked light will be on as well
Consider that these bulb have a tendency to burn out over time and that it is common for people to have flashing lights but still have a normally functioning 4wd system
If the four wheel drive is on the light will indicate green light in all the wheels.
The other is for higher end if you get stuck and the lights will be different.
Do you know how to fill the washer fluid in the head lamps washer. my light is on and i CANT FILL THE WATER IN THAT
paj_me
Apr 12, 2011 05:58 PM
greengrounds
Jan 20, 2010 06:59 PM
RussellM
May 13, 2009 09:58 AM
