pajero super select 4wd indications
Old Mar 3, 2008 | 10:41 PM
testament11's Avatar
Default pajero super select 4wd indications
hi guys, i just recently bought a used pajero exceed 2nd generation 2.8L. i just want to know, how would i know if my 4wd mode is in:
A. 4H
B. 4HLc
C. 4LLc
thanks.
Old Mar 8, 2008 | 01:21 AM
xyzik's Avatar
Default RE: pajero super select 4wd indications
no light indicators? no shift pattern on the transfer case ****? what year is this?
Old Mar 11, 2008 | 11:44 PM
no, ther are light indicators and **** indicator. just wanna ask how does the indicator react to the following 4wd modes
Old Mar 28, 2008 | 06:50 AM
nicolaselias's Avatar
To the best of my knowledge, when in 2wd just the rear wheel lights should be on, in 4h, the 4 green lights will be on, then once you get to 4 hlc or 4llc the orange centre differential locked light will be on as well
Consider that these bulb have a tendency to burn out over time and that it is common for people to have flashing lights but still have a normally functioning 4wd system
Old Sep 13, 2011 | 02:42 AM
brahmanandan malapurathattil's Avatar
If the four wheel drive is on the light will indicate green light in all the wheels.
The other is for higher end if you get stuck and the lights will be different.
Do you know how to fill the washer fluid in the head lamps washer. my light is on and i CANT FILL THE WATER IN THAT
Dsmoovy
Nov 21, 2011 03:00 PM
paj_me
Apr 12, 2011 05:58 PM
greengrounds
Jan 20, 2010 06:59 PM
RussellM
May 13, 2009 09:58 AM
sandygarf
Sep 6, 2008 11:13 AM
