Question on lug nuts for my Montero Limited 2002
Old Apr 30, 2006 | 03:00 AM
marcmindte's Avatar
Default Question on lug nuts for my Montero Limited 2002
Hey guys,
Finally getting rid of my 16's and putting some 20's on. What size of lug nut fits? Right now my lug nuts are to "wide" to fit on my new 20's (see attachments). The one on the left is what is on there right now holding on my 16's, the one on the right is what come with my Wheels, but the "inside threading" (picture 2) just slips over the bolt, so my tires wont stay on. Do you know the thread size for lug nuts so I can go by 24 new nuts and my tires wont come off when I drive down the road?
Thanks
Old May 1, 2006 | 06:22 PM
michaeljr5's Avatar
Default RE: Question on lug nuts for my Montero Limited 2002
The lug nuts that are on the factory rims are specifically designed for the hub centric style of rims they put on the trucks. You will have to find a set of lug nuts to fit that go with your new rims.
Old May 7, 2006 | 08:24 PM
mikeinfhaz's Avatar
similar question, how hard is it to remove the lug nuts from my rotors and add them into new rotors? Is there a set tool or simply unscrew them? thanks
Old May 8, 2006 | 05:04 PM
off roader's Avatar
ORIGINAL: mikeinfhaz
Do you mean the lug bolts (part that you screw the nuts onto)??
Re-using lug bolts is not advisable since they're pretty inexpensive. I recommend buying a set rather than reusing them off an existing vehicle. IIRC, someone once told me that the lug bolts and nuts should be replaced regularly... Something like every time you get new tires or so but perhaps someone who's more knowledgeable can chime in on that.
Old May 8, 2006 | 07:02 PM
mikeinfhaz's Avatar
yeah lug BOLTS, my bad duh
I'll look into the price for new ones unless you can provide a link
thanks man
Old May 8, 2006 | 08:17 PM
michaeljr5's Avatar
I have never had to replace a lug bolt I haven't broken. I've never seen them "wear out." I know you can find a set of regular lug bolts to fit the lugs on your monty, call NAPA, PEP boys, Autozone, schucks or whom ever. Tell them you need a set of lug bolts to mount steel rims on a Montero/Montero Sport. If the tech knows anything, they should be able to help.
Old May 8, 2006 | 10:17 PM
off roader's Avatar
ORIGINAL: michaeljr5
I agree but what was relayed to me is that lug bolts do age and wear out with time so depending on the wear on his bolts it may make sense to know about it. Note that I haven't followed this "recommended" practice either.
Also, I agree that most any car parts store will have them available.
jjrphs
Aug 13, 2015 08:47 PM
Catch22!
Aug 19, 2007 10:44 AM
Wingo171
Aug 11, 2007 06:02 AM
livetoride20000
Aug 30, 2006 12:55 AM
ictponder
Apr 29, 2006 02:05 AM
