Re: Power brake booster replacement on a 03 Montero Sport
Old Dec 1, 2017 | 04:48 PM
advisual's Avatar
Default Re: Power brake booster replacement on a 03 Montero Sport
I'm getting a vacuum sound when I go to apply the brake on my Montero Sport.
I believe the power brake booster needs to be replaced.
Is this a difficult r&r?
Any tips or suggestions on this job?
Any links on replacement for a 03 Montero Sport LS 3.0?
Thanks
Old Dec 9, 2017 | 10:00 AM
montymecrazy's Avatar
What does a 'vacuum sound' sound like?
On my '02 limited I started hearing a sound like a bird chirping from in front of the driver position (under the hood) whenever the brakes were pressed but that turned out to be the power brake accumulator. That was an easy 5 minute replacement. I forget how much the part cost but I think less than $50.
Old Dec 9, 2017 | 03:41 PM
It should not be a hard job. Couple bolts and few clips. The mounting bolts for it are on the inside of the firewall - might be a little tough to get to. You'll be re-using the master cylinder, unless it is bad.
If you have a leak in your vacuum brake booster, you need to address it because 1. your brakes are not functioning at 100% power; 2. Eventually you'll get a Check Engine Light because you have un-metered air entering the intake manifold.
michaeltroy
Feb 27, 2015 09:06 AM
michaeltroy
Jan 30, 2015 08:50 AM
michaeltroy
Dec 29, 2014 08:09 AM
johvig
14
Apr 1, 2012 07:59 PM
leejm12
Aug 3, 2010 08:28 AM
