rear suspension toe bar adjustment bolt missing/broke
Old Apr 17, 2011 | 10:32 AM
mtc137's Avatar
Default rear suspension toe bar adjustment bolt missing/broke
The toe bar eccentric adjuster nut is missing/broke off the driver side rear.
The bar doesn't look rusted, only the bolt/bolt assembly, I can't tell if it's broke off or just missing the nut. Either way, I gotta fix it.
What is my best course of repair?
Do I need to replace the entire bar or just the adjustment bolt assembly?
Are there bushings inside that bar that need to be replaced?
Thanks
Old Apr 17, 2011 | 09:24 PM
Mr. Z.'s Avatar
If it were my rig, I would take the assembly apart to inspect everything throughly. Make your decision based upon what everything looks like. If you can simply replace the nut, then order just that. (A bit of anti-seize will do wonders for nuts in the under carriage area.) Be sure to use the specific torque specs. for you model monty when reassembling the suspension.
Good Luck
Old Apr 22, 2011 | 12:11 PM
mothman52's Avatar
Great advice Mr. Z. Do you have those specs & procedures, mtc?
babacu
Dec 25, 2012 06:37 PM
frank101
Feb 19, 2012 10:43 AM
softmouthfrogdog
Apr 27, 2010 12:39 PM
tchun
Apr 15, 2005 11:10 PM
antomx
Sep 29, 2004 02:32 PM
