Replacing valve guides and stem seals
Old Feb 12, 2009 | 04:26 AM
Skiddy's Avatar
Default Replacing valve guides and stem seals
What else would it be advisable to replace when replacing the two? I've already bought valve cover gaskets, and have been told to replace the oil seals. Anything else to add to the list? Thanks.
Old Feb 12, 2009 | 04:47 PM
Manybrews's Avatar
Default RE: Replacing valve guides and stem seals
you cant replace valve guides without cylinder head removal. So you'll need an entire upper engine gasket kit. Also, it would be helpful if you told us what you're driving.
Old Feb 13, 2009 | 03:13 AM
Skiddy's Avatar
Sure, it's a 2000 Pajero/Montero with a 12-valve 6G72.
Old Mar 4, 2009 | 11:09 PM
lunning's Avatar
You will also probably need to recut the seats and grind the valves if they are not new to make sure there is a good seal between the two. When you replace the guides the center point can change enough to cause problems.
quechon
Feb 2, 2022 07:35 PM
newoutlanderfan
Aug 20, 2013 06:47 AM
drakerr
Jan 20, 2013 03:42 PM
Skiddy
Nov 26, 2008 08:41 PM
dksnj
Jan 2, 2007 12:41 AM
