Retrieving engine codes
Old Nov 23, 2007 | 06:26 PM
Akmikek's Avatar
Default Retrieving engine codes
I have a 95 montero sr and my engine light has been coming on. Is there a way to retrieve trouble codes without a reader?( ie..jumper wire,reading cluster light)?Is a 95 OBD 2 compatible?
Old Nov 23, 2007 | 06:43 PM
jpmontero98's Avatar
Default RE: Retrieving engine codes
should be....go to a dealer or autozone to check it out
Old Nov 23, 2007 | 08:14 PM
dsm1990gsx's Avatar
Some cars built in 95 had the obd II connector are compatable, try taking it to autozone and see if there scanner works, if not you might have to take it to the dealer.
Old Nov 24, 2007 | 07:04 AM
Akmikek's Avatar
We dont have a Autozone. Only a small autoparts store.
Old Nov 24, 2007 | 08:44 AM
dsm1990gsx's Avatar
Well if your were in PA I would be able to scan it for ya, but try a couple of small shop and see if they can scan it for you. They shouldn't charge you just for giving u a code.
Old Nov 24, 2007 | 10:19 AM
Akmikek's Avatar
Thanks, i will give a couple shops a try. Is a 1995 compliant? I would go buy one if i knew for sure?
Old Nov 24, 2007 | 10:27 AM
dsm1990gsx's Avatar
It really depends on the car, I know chevy and some fords were obIIcompliant in 1995. Check under the dash for a 16 or 17 pin dlc connector. 1996 and up are obII compliant.
Old Nov 24, 2007 | 05:19 PM
Akmikek's Avatar
I discovered that if you put a jumper in #1 slot of 16 pin connector and ground it then you can turn on ignition and the Maint. light will blink the codes. It was onelong then one short (11). My book said it is the heated O2 sensor. I need to chec it out i guess. I can reset the ECM and drive and the engine light stays off until i get up to about 50 mph for a certain amount of time then it comes on again.
Old Nov 25, 2007 | 07:54 AM
dsm1990gsx's Avatar
Well there you go, I learned something today. You probaly got a tired o2 so just replace it.The light willcome back on eventually.
Old Dec 27, 2013 | 09:42 PM
Big Pete's Avatar
Default trouble retrieving codes
Hello...I have just purchased a 2000 Montero sport and I have a question...
My check engine light is on and I went to Oreilly to have them read the codes and a weird thing happened. When he hooked up the scanner and started to scan...the speedometer went from 0-approx 60mph then the scanner said it couldn't connect.
he tried this another time and the same thing happened.
Weird huh?? any thoughts?
Davie-h
Nov 11, 2013 01:25 PM
membreya
Apr 18, 2013 12:50 AM
BernaskiBLAZE
Aug 17, 2006 11:30 PM
Dragonslayer
Jun 15, 2006 02:59 PM
agallardo
May 4, 2006 12:18 AM
