RPM's jump around
Old Aug 21, 2007 | 12:37 PM
benchman's Avatar
Default RPM's jump around
On my '99 Montero Sport ....when going around 30 to 40 MPH the RPM's jump up and down between 1200 and 1500 rpm's. You can feel a bit of hesitation when this happens.
The sport has about 72,000 miles on it.
It ridesfine on the highway.
Any idea's??
Old Aug 21, 2007 | 04:37 PM
carlover626's Avatar
Default RE: RPM's jump around
Can you describe this a bit more? Are you giving it gas when it does this, or coasting?
MY first thought is the transmission (shiftingto4th and back to 3rd), have you had the fluid flushed as recomended? How about the other maintenance (plugs, wires)?
Old Aug 21, 2007 | 05:14 PM
benchman's Avatar
I'm just coasting......and I think it's in the 4th gear but doesn't like the lower rpm's in 4th gear. It runs fine if I manually put it in 3rd.
I'm probably due for some basic maintenance.
I asked the same basic question with a little more detail.on this forum back on Aug. 9 under the headline "Rumbling noise".....but didn't get much response
benchman
Old Aug 21, 2007 | 05:33 PM
Yeah my 4th gearis pretty worthless at 30-40 MPH, it may be shiftingup automatically to 3rd??
You say it's jumping up and down, does it do it many times at once - up / down, up / down, up / down or just once? If it is continuous you *may* have a vac leak.
Your comment of "Im probably due for some basic maintenance" makes me think you need to catch up on that before troubleshooting too much.
Old Aug 21, 2007 | 05:56 PM
benchman's Avatar
The rpm's go up and down about 3 or 4 times in the stretch of a block or two then I'll either break or slow down (small town driving) or speed up.
It's annoying (mainly to my wife!).........she bugs me about it.
I'll see about getting some maintenance done and then see how things are doing..........Thanks!
randya
Feb 9, 2009 12:53 AM
antox18
Jun 21, 2007 08:50 AM
natewesselink
Feb 9, 2007 07:55 PM
Hub1982
Aug 12, 2006 06:29 AM
agood1
Feb 3, 2006 04:51 PM
