Rumbling noise
Old Aug 9, 2007 | 10:47 PM
benchman's Avatar
Default Rumbling noise
I've got a '99 Montero Sport ES with a 3.0L......with about 73,000 miles on it.
When I first heard this noise, I thought it was the tires running over rough patches of road. It's a rumbling noisesimilar torunning over the "warning" ridges in the highway when your approaching a stop sign.
I finally narrowed down the fact that the noise happens between 30 to 40 miles per hour, when the RPM's are around 1200to 1500 and I'm lightly accelerating. If I'm accelerating rapidly (like getting on the interstate) it doesn'thappen.
There is a hesitation in the engine when this happens and the RPM's take a little dip.The noise stops if I take my foot off the gas or I speed up past the 1200-1500 RPM mark.
Any thoughts??
Old Aug 10, 2007 | 01:38 AM
crow's Avatar
Default RE: Rumbling noise
I have almost the same problem on my monty sport 3.5 mine is engine hesitation and a very recent check engine shows of an oxygen sensor malfunction..now i am having it checked which one of the 4 sensors, I got a quote for all 4, and it ranges from 100-200 usd each[:@]
Old Jan 16, 2008 | 01:10 PM
jordan's Avatar
Did anyone ever find out what causes this problem. My 2001 Montero is doind the same exact thing? I'm going crazya dnd I can't seep to find the dolution. Id u could be of any help please.
Old Jan 16, 2008 | 01:51 PM
montero1's Avatar
I'd think an 02 sensor would throw the check engine light.
From the symptoms of the original poster, I'd say it was either wheel bearings, driveshaft, or U-joints.
Old Jan 16, 2008 | 02:42 PM
carlover626's Avatar
I recall reading something about theTorque Converter Clutch(TCC) causinga "vibration".I posted this in the “Carrier Bearing†post as well.
Benchman - do you feel a vibration or only hear a rumbling?
https://mitsubishiforum.com/m_105430..._1/key_/tm.htm
https://mitsubishiforum.com/m_35021/tm.htm
http://www.4x4wire.com/forums/showfl...v=#Post1012948
Old Jan 16, 2008 | 09:36 PM
benchman's Avatar
I get some mild vibration/shuddering and I hear a mild rumbling. It's most notable when going up the on ramp (30-40 mph) onto the interstate.
The Torque Converter Shudder really sounds like my problem. The Flush and refill with the Mitsubishi SPIII sounds like a good place to start.
benchman
Old Jan 16, 2008 | 11:10 PM
ORIGINAL: benchman
benchman
I get that same type of vibration (plus another constant one @ 19-20 MPH) and have sinceI got the MS last January. I took it toa Mitsdealer like a week after I got it and they said the only thing they could get to vibrate was "possibly" the rear diff. I then took it back to where I got it (A VW dealership) and they had it looked at by another shop that changed the diff fluid and told me all was well.
The Tranny fluid has been flushed (90K Maint.)atyet anotherMits dealer and my vibration is still apparent.
Old Jan 26, 2008 | 04:46 AM
mxmikie's Avatar
water pump
Old Feb 2, 2008 | 12:07 AM
jgbrules's Avatar
hello!! what you are feeling is torque converter shudder, caused by either contaminated fluid or the wrong fluid. it can easily be fixed by having a trans FLUSH done. drain and fill wont due. HAVE TO USE MITSUBISHI FLUID. no exceptions. it might take up to 100 miles after flush is done for shudder to completly go away, but you should notice a difference right away.
phils06gt
Apr 18, 2012 12:10 PM
treyflame
Sep 15, 2011 10:19 AM
treyflame
Sep 15, 2011 10:18 AM
pedalon
Jan 6, 2004 02:54 AM
dbmits
Sep 19, 2003 06:25 PM
