Sender for 3 Gauges on Dashboard ??
Old Nov 20, 2007 | 12:41 PM
Warren C's Avatar
Default Sender for 3 Gauges on Dashboard ??
I have removed a set of the three gauges on the center of the dashboardfrom a wrecked Montero Sport and would like to install them on another car.
There's a mechanical inclinometer, an altimiter, and a guage on the left that's blank ..not sure what it is. Can someone tell me.
I assume there must be a sensor/sendor unit for the left and right side guages. Can someone tell me where it is located so I can get it?
Warren C.
Old Nov 28, 2007 | 07:40 AM
MATMEG's Avatar
Default RE: Sender for 3 Gauges on Dashboard ??
Hi, I know the Oil pressure gauge has its sensor in the block... lower left side (facing the engine). TheVolts gauge should be a wire posted on the alternator...pull the small wire and check to see if the gauge stops working.
tellecu
Feb 2, 2009 04:33 AM
Thirdorb
Apr 10, 2006 05:02 PM
ninety5eclipz
Mar 27, 2006 01:42 PM
marvinmc
Mar 22, 2006 11:18 PM
kayzee
Feb 6, 2004 04:27 AM
