SHOULD I BUY THIS 97' MONTERO SPORT?
Old May 24, 2005 | 11:48 AM
VITIFONZ's Avatar
Default SHOULD I BUY THIS 97' MONTERO SPORT?
It's an LS two tone with all options but the 4x4 which I don't need. Selling for $5,700.00 with 165k drives strong and A/C works fine, has the "chek engine" light on? What should I look for before purchase and can fight the price?
Thanks...
Old May 24, 2005 | 01:29 PM
Winshawn's Avatar
Default RE: SHOULD I BUY THIS 97' MONTERO SPORT?
Find out what the code is for the Check engine light. It could be cheap or it could be expensive. Most chain auto parts stores will check the code for you for free.
Check to see when the timing belt was changed. Generally needs to be done every 60-80k. It is a pretty big job to change the timing belt. 6-8hrs.
Check when the plugs were changed a find out what kind of plugs were used. They need to be changed every 60 but you need to use the $10-15 douple platinums or they will not last very long. It is a 2-3hr job to change the plugs.
At that mileage the water pump will need to be changed soon too.
Old May 24, 2005 | 02:12 PM
VITIFONZ's Avatar
Thanks Winshawn for the info. if any one has a carfax acct I'll appreciate the look-up VIN# JA4LS31P1VP010839 ?
THANKS AGAIN!!!!
Old Jul 21, 2005 | 06:53 PM
03montero's Avatar
car fax is clean on this suv originated out of La and no bad history noted other than high miles and was serviced at 140,000 and sold at auction I just bought my montero and after running more than 30 of them thru carfax 2 came up clean so people be careful when shopping for used ones as the dealers seem real shady here in Florida.
Old Jul 22, 2005 | 07:52 PM
VITIFONZ's Avatar
Thanks for the info. Had to give it back...the crankshaft pulley nut got lose and almost got in accident driving!!!
jalex1941
Feb 11, 2014 03:12 PM
Twisted
Mar 12, 2013 10:47 AM
surfcandy
Jul 31, 2010 10:11 AM
mitsustigi
May 23, 2009 08:21 PM
lunarcry
Dec 19, 2003 06:32 AM
