Speedometer Cluster Change...Please Help!
Old Mar 16, 2008 | 04:36 PM
wildwestzx's Avatar
Default Speedometer Cluster Change...Please Help!
Hello everyone...
I have an 02 Montero Sport ES. I've had problems with a couple of my gauges so I'm swapping the cluster out. The odometer is digital, will the mileage transfer to the new cluster, or will the junkyard cluster's mileage show???
Please, if you know the answer for sure, help!!!
Thanks for your time,
Steve
Old Mar 16, 2008 | 06:13 PM
Joel_CA's Avatar
Default RE: Speedometer Cluster Change...Please Help!
The speedometer mileage of the new cluster is what will be displayed wether it be higher or lower than your existing mileage. When i worked for Mitsubishi- we generally shipped out both the old cluster and the replacement cluster to a company called Specmo Enterprise. They'd generally burn in the current mileage fo the failed cluster into the new one. You can reach them at www.specmo.com.
JJ
giordano60
4th Generation
Jun 15, 2019 03:52 PM
CONUNDRUM415
Feb 11, 2013 04:54 PM
Heretic16
Apr 28, 2008 12:20 AM
Eclipse440
Jan 16, 2008 07:49 PM
g9s5t
Aug 9, 2005 11:39 AM
