Sport vs xls
Old Jul 25, 2015 | 05:38 PM
Originally Posted by Guyfromhe
I don't know why they make 2 different models with the same name it's very confusing...
They do not have the same name. One is Montero, the other one is Montero Sport. There are other brands that do a similar naming, however they are more of trim levels. In Mitsubishi's case they named the "baby" Montero - Montero Sport
Originally Posted by jp1985
...do both sport and the full size both have all the same 4wd options(like 2wd,awd,4hi,4low)?
I know for sure that full size Montero does come with all four types of drive (2wd, 4awd, 4x4, 4x4 low). I can't say for the Sport model (I own full size). I hope folks who have Montero Sport can weigh in on that issue.
Old Jul 25, 2015 | 05:43 PM
jp1985's Avatar
yes that's what i am looking for info on if the sport has all of the drives as well. If not i will probably go big .
Old Jul 25, 2015 | 06:05 PM
Guyfromhe's Avatar
I realize this, they did this with the Outlander and the Outlander Sport (RVR) which are big and baby versions of basically the same car.
However when you look at the "Montero Limited" and "Montero XLS" the "Montero Sport" they all look like it's the same car with a different trim packages when it's not the same car at all if you don't know the brand/model well it can be very confusing.. That's all I am saying... There's probably a reason mitsu has different naming for the car in the US and Canada...
I assume there's a trim package name on the Sport too but I guess having 2 words already people tend to leave it off?
Old Jul 25, 2015 | 08:09 PM
jp1985's Avatar
Do monteros really requires premium fuel?? i was looking at Edmund trying to figure out the stats and they said it requires premium fuel.
Old Jul 25, 2015 | 10:08 PM
Completely agree. Especially that in 90% of other brands that would refer to different trim levels of one model.
Old Jul 25, 2015 | 10:17 PM
The Owners Manual does specify to use Premium fuel. When I just got my Montero Ltd, I used only premium fuel in it. Then some years later, when the gas prices started to rocket up, I switched to regular gas (87 octane) out of necessity. I did not notice any adverse affects in doing so - fuel efficiency stayed about the same, no knocking, no detonation. Over many years of travel (over 187k miles) I did not notice any said adverse effects at sea level or at 3,000-4,000 ft elevation. Still using regular gas
Old Jul 26, 2015 | 12:03 PM
Guyfromhe's Avatar
My Outlander used the verbiage "Premium recommended" I used premium a couple times and I noticed absolutely no difference. I had my scan tool with the knock sensor count on for the first few months and never saw it go above 0.
Old Mar 8, 2024 | 07:50 AM
Dannico's Avatar
Default 2001 Montero XLS and Limited vs Motero Sport
Thank you! this is what i have been wondering. So do both sport and the full size both have all the same 4wd options(like 2wd,awd,4hi,4low)?
I wish they had gen 3's around here with manuals i do belive i have seen one before however it was not for sale.
Is one more suited for off road than the other?
again thank you for the info.
JP
the pictures in the links above are of a 2001 Mitsubishi Montero XLS /Limited Sport Utility 4D and a 2001 Montero Sport.
it can get confusing which, is which,
this is a 2001 Montero Sport
and this is a 2001 Montero XLS or Limited
the XLS has part-time four-wheel drive, with a two-speed transfer case and mechanical shift on the fly.
The Limited has ActiveTrac and is electronically engaged and splits torque in a more asphalt-friendly 33/67 front and rear in all-wheel-drive mode.
I love my XLS
XLSmontero
Sep 1, 2006 12:19 PM
jkalet
Aug 18, 2006 12:53 PM
caverspencer
May 31, 2006 01:53 PM
frohboy33
Apr 7, 2006 02:07 AM
millerl513
Aug 4, 2004 10:24 AM
