Stalling montero sport
Old Jan 6, 2009 | 11:10 PM
switch28's Avatar
Default Stalling montero sport
Hello all!! I really hope someone can help me, I have a 98 montero sport that is running weird. I purchased it with a dead battery and bad alternator. When it is cranked up it runs fine for a min and then it starts pulsating and when the throttle is pressed it dies. I have replaced the fuel pump, alternator,battery,fuel pressure regulator,ecu,maf sensor, and the fuel filterand it still does it. When it is running bad I can unplug the maf sensor on the intake and it levels out and runs fine as long as it isafter it warms up. Please someone help, I have spent over $500 guessing. Oh when I purchased it, it also had a bunch of blown fuses including a 15amp and a 100amp fuse under the hood.
Thanks,
James
Old Jan 6, 2009 | 11:47 PM
saltinecracka's Avatar
Default RE: Stalling montero sport
some one hooked the battery up backwards. may have some bad relays, or even burned up some wiring. good luck.
Old Jan 7, 2009 | 06:45 AM
switch28's Avatar
Yeah I was thinking that to, but everything seems to work and I have not found any bad wires yet. My dome lights dont work for some reason but I am sure it has nothing to do with the stalling.
Old Jan 8, 2009 | 06:40 AM
switch28's Avatar
Is there anyone else out there that can help me with my problem?
Old Jan 8, 2009 | 06:53 AM
4g54's Avatar
maybe its time to get yourself a mech or wireman.
like sw28,i think its electrical.something to do with the maf sensor wiringmaybe?
Old Jan 8, 2009 | 08:44 PM
switch28's Avatar
It could be the wiring but for what I can see everywhere that I checked everything seems fine. I had it checked on a computer at advance auto and it came up with a strange code that they never heard of. I think it was obd 2 bank 1 something like that. I looked up the code on the e-net and I read were it had something to do with the maf sensor so I replaced it and still nothing.
Old Jan 8, 2009 | 11:05 PM
struculeus's Avatar
It almost sounds to me like a fuel problem.
1. Check for vaccuum leaks with carb spray. Spray it on all the vaccuum hoses, intake rubber,intake manifold, etc... If the engine stutters, there's your leak.
2. I had a very similar problem with a Volkswagen. It ended up being the fuel injectors. I'd check those.
Not sure if it helps, but it's something to explore! Good luck.
Jared
Old Jan 11, 2009 | 03:23 PM
challenger4x4's Avatar
Most likely the IAC memory was erased when the battery died. Common problem. You need to clean the throttle plate and throttle body bore. Procedure is here: http://msport97.proboards6.com/index...ay&thread=6258
Old Jan 11, 2009 | 04:48 PM
dsm1990gsx's Avatar
Check your fuel pressure and post up what it is. An iac would cause a car/truck to stall but if you give it gas it shouldn't die. I am betting you have a fuel related issie.
Old Jan 23, 2009 | 07:00 PM
switch28's Avatar
Sorry I have not been back, I did not think anyone was replying and I use 2 different emails. Anyway thanks for everyones suggestions but I have already cleaned the entire throttle body and inside of it and wiped it down. I have replaced the fuel pump, fuel pressure regulator and fuel filter. I have also changed the ECU recently and all the relays under the hood. It still runs like crap, it cranks up and runs fine until it warms up then it starts dieing out and when you give it gas it stalls unless you pump it a bunch of times. But if you unplug the mass sensor it runs fine or if you take the engine relay out while its running it idles good again. I am very confused and I got 5 codes off the computer and the first one was the IAC then the mass sensor twice and the camshaft position sensor last. So I am going to try changing the IAC if I knew were it was at on the throttle. Please help anyone THANKS!!
