Stalling montero sport
RE: Stalling montero sport
there is a T.S.B about this problem. you could have a bad fuel pump control module. and yes it is seperate from the e.c.u. same symptoms as i recall. been awhile since i have seen one. make sure all of your fuses and relays are good, since some were blown, that concerns me. they dont blow for no reason.i dont remember the T.S.B number, i think even this website has T.S.B' s. it will be in group13 which is the fuel category. good luck!!! greg.....
stalling montero sport
Normally that is happening to me every time the battery is disconected
all you have to do is
1 start the car leave it running for 15 minutes do not touch
2 after the car get the temperature normal operations or half of the micrometer. turn off the car and turn the car righ-oway on again after this procedure is done it should work properlly.
thank you
thank you
