Stalling montero sport
Old Jan 28, 2009 | 12:12 PM
imtofc's Avatar
Default RE: Stalling montero sport
I have the exact same problem in my 02, same blown fuses, everything, did you find the salution yet, Please let me know if you do?
Thanks
Old Jan 30, 2009 | 08:11 PM
switch28's Avatar
No I have not found the solution yet but I think its the Idle air control valve. I just sold the truck so now its for someone else to figure out.
Old Feb 5, 2009 | 10:43 PM
jgbrules's Avatar
there is a T.S.B about this problem. you could have a bad fuel pump control module. and yes it is seperate from the e.c.u. same symptoms as i recall. been awhile since i have seen one. make sure all of your fuses and relays are good, since some were blown, that concerns me. they dont blow for no reason.i dont remember the T.S.B number, i think even this website has T.S.B' s. it will be in group13 which is the fuel category. good luck!!! greg.....
Old Feb 6, 2009 | 04:31 PM
Manybrews's Avatar
if someone jumped the battery backwards, the fuel pump module is toast.
Old Jan 7, 2011 | 02:47 AM
wjelmer's Avatar
so was it the fuel pump control module?
Old Jan 19, 2011 | 06:00 PM
rmejia's Avatar
Default stalling montero sport
Normally that is happening to me every time the battery is disconected
all you have to do is
1 start the car leave it running for 15 minutes do not touch
2 after the car get the temperature normal operations or half of the micrometer. turn off the car and turn the car righ-oway on again after this procedure is done it should work properlly.
thank you
bella10
Dec 21, 2013 09:00 AM
GTB323
Mar 27, 2010 09:38 PM
autorok
Jul 1, 2005 02:33 PM
get435
May 22, 2005 03:12 PM
1998blackgst 240
May 9, 2005 07:50 PM
