Starting problem
Old Nov 29, 2016 | 01:36 PM
MrsDavis's Avatar
Default Starting problem
Hello I have a 2000 Mitsubishi Montero Sport 3.0L v6 LS and I was told that it was a bad fuel pump so I changed the relays, filter, pump, and sock, but it still won't start what else could it be
Old Nov 29, 2016 | 04:35 PM
Did you verify that you have fuel delivery before and after the work?
Crank - No Start condition is usually caused by one (or more) of the following issues:
No Spark
No Fuel
No Compression.
Check them one at a time (before replacing any parts) to see what is the primary cause. Then troubleshoot to find out why something is not working and what is causing the malfunction.
Old Nov 29, 2016 | 05:26 PM
MrsDavis's Avatar
I have checked them all one by one and still nothing I have put new spark plugs new crankshaft position sensor and new fuel pump and filter I have everything and fuel is getting up to the rail
Old Nov 29, 2016 | 08:02 PM
That is incredibly puzzling...
What are your compression values (both dry and wet)?
What is the condition of your air filter?
Originally Posted by MrsDavis
... filter I have everything and fuel is getting up to the rail
Fuel getting to the rail... Do your injectors work? If they do not operate, fuel in the rail is not enough.
Old Nov 29, 2016 | 08:56 PM
MrsDavis's Avatar
I found the problem finally
Old Nov 29, 2016 | 10:08 PM
The Silent Seed's Avatar
It would have been nice to tell us what the problem was.
Old Nov 30, 2016 | 10:21 AM
MrsDavis's Avatar
It was the fuse under the dash haha leave it to a woman not to check all the fuses
Old Nov 30, 2016 | 10:22 AM
VelvetGlove's Avatar
Please tell us what your solution was. I have an 02 in the shop with the same start up issue.
Old Nov 30, 2016 | 10:23 AM
Thanks!!
That makes 2 of us who didn't check the fuses....
MrsDavis's Avatar
Oh and under the hood the 20a oeg fuse
vic453
Nov 13, 2005 09:04 PM
CCUBoy05
Oct 4, 2005 11:25 AM
jcp3alex
Sep 27, 2005 10:17 PM
bushboy
Sep 5, 2005 07:30 AM
vic453
Aug 2, 2005 04:37 PM
