Steering wheel scraping noise
Old Jan 10, 2009 | 03:10 AM
Skiddy's Avatar
Default Steering wheel scraping noise
When I turn my wheel, there's a plastic on plastic like scrapping noise. It happens when the wheel is turned to either side from the center. Any ideas as to what this could be? Vehicle's a 2000 Pajero. Thank you!
Old Jan 10, 2009 | 11:12 AM
nativa's Avatar
Default RE: Steering wheel scraping noise
put some petroleum jelly between where the steering wheel and the column touches
Old Jan 11, 2009 | 02:18 AM
Skiddy's Avatar
Just had a look at it again, and the steering wheel is not touching the column. The noise is coming from the upper part of the column, near the steering wheel. Could some dust or sand gotten in there by any chance? Thinking about blowing it out with compressed air, but then again do not know how useful it would be.
Old Jan 11, 2009 | 08:25 AM
dsm1990gsx's Avatar
Check your power steering fluid level. If its low the pump and rack will make a noise and that noise travels up the column to the steering wheel.
Old Jan 11, 2009 | 01:29 PM
Skiddy's Avatar
Thanks! Just checked the fluid level, and it was a wee bit under the MAX mark. I topped it up, but unfortunately the noise still hasn't gone away.
Old Jan 11, 2009 | 01:58 PM
dsm1990gsx's Avatar
Try lubricating the steering colomn.
Old Jan 11, 2009 | 02:02 PM
nativa's Avatar
i wasnt jokin try the jelly, wont hurt.It fixed someone's problem b4.
Old Jan 12, 2009 | 03:53 AM
Skiddy's Avatar
I'm giving that a try, thanks!
Old Feb 8, 2009 | 06:26 PM
rjr325's Avatar
my 2001 montero limited had same issue, sprayed a little wd-40 where the steering colum goes through the firewall. problem solved.
dashnine
Dec 14, 2023 04:56 AM
PalmSprings
Dec 12, 2013 06:52 PM
rustyc
11
Sep 9, 2010 07:03 AM
FatalJRA
Dec 5, 2004 03:34 AM
FatalJRA
Dec 2, 2004 10:08 PM
