Temp gauge problem
Old Mar 7, 2015 | 02:19 PM
Steve_qs's Avatar
Default Temp gauge problem
Hello, I'm Steve and I have a 02 Montero LTD. During this past winter I've had a coolant and...I believe an electrical power problem.
-The check engine light has been on since I got it inspected which I'm sure is a catalytic converter prob. but it went off recently fo about a week...then came back on. Now the engine light is off again.
-During this time, the dome light that comes on inside the truck when you open the door stopped coming on for about two to three weeks. Now I get in my truck a few days ago to warm it up in the morning and click the unlock button to make sure it's unlocked and the dome light just turns on.
-The biggest worry I have though is that yesterday when I'm leaving work...I turned on the ignition and the temp gauge just SPIKED immediately, right when I turned on the ignition. This has never happened before. I drove the truck a bit on the way home and at first, the needle went down to normal for a sec but went up then down about a quarter and then up and it's been up to the top ever since. I stopped a few times in some parking lots to see if it was over heating and it isn't. No antifreeze smell or steam or anything. It does have a coolant leak but it's not bad and I keep it full and check it. The gauge just stays at the top. I'm thinking electrical or computer. I just checked it I just replaced the alternator about two years ago. Can anyone help with info on this problem? Thanks in advance
Old Mar 7, 2015 | 02:36 PM
TheMole's Avatar
Common problem with the temp gauge. Should be some threads covering this already just do a search.
https://mitsubishiforum.com/forum/mi...p-gauge-47609/
Old Mar 7, 2015 | 10:29 PM
Yep, temp gauge reading error is very common. Scary as hell when you see it for the first time too. I feel for you. Check the link TheMole posted there are some resources there on how to deal with it.
eclipsekid85
May 15, 2006 02:20 PM
eclipsekid85
May 14, 2006 10:15 PM
wolfman
Oct 29, 2004 06:39 PM
