Timing
Old Nov 26, 2008 | 05:19 PM
98 Montero's Avatar
Default Timing
Replace timing belt 1yr ago. Bolt broke to tensioner. Timing marks on both heads and crank at different positions. How do I know if I bent any valves. Was doing about 35mph when it happened.
Old Nov 27, 2008 | 09:40 AM
4g54's Avatar
Default RE: Timing
surely the valve will be bent.
u feel any significant power loss or any abnormal sound?
i'm dont know much about bent valve but all case i've hear off will hav bent or destroyed valve depending on the speed it happen.
Old Dec 4, 2008 | 05:49 PM
SyntorX's Avatar
Default RE: Timing
My belt failed in a similar way
while you were going 35 this happened....did you use the starter to try to restart the vehicle?-big no-no
The only safe recourse is to pull the heads and have them inspected, at the very least. I had mine (2002 MonteroSport) both rebuilt for 180 bucks- I supplied the parts.
Get a new belt and water pump and pullies (use all new hardware/bolts)....take a lot of pictures on the disassembly!!! It saved me a TON.
Good luck.
marshmallow746
Jun 10, 2022 10:20 PM
judien
Mar 9, 2018 03:41 PM
sherk
Mar 5, 2013 10:47 AM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
