Timing Belt change Dealer vs Independent shop
Old Mar 21, 2011 | 07:49 PM
  #21
redturboeclipse's Avatar
i usually dont have a problem sending it to another auto shop, but with the montero due to the rare support it has in the US.. i just seem more to leaning to pay extra to have the dealer do the work. but when the time comes who knows.. im sure I will just go with one of my trusted local shops.
Old Mar 21, 2011 | 11:13 PM
  #22
A timing belt is not something you want to screw up.
Old Apr 5, 2011 | 07:03 PM
  #23
7-UP BILL's Avatar
Originally Posted by tj90
inquired about the cost of doing a transfer case lube change. I inquired what type of gear lube they use (GL-4, vs Gl-5) and the manager had no idea what I was talking about. He said that all transfer cases and differentials get the same gear lube. LUBE CHANGES ARE THEIR BUSINESS! GL-5 hypoid gear lube in a xfer case is a big no-no!
I would like to know why GL-5 gear lube in the transfer case is a no-no? My manual says to use it. What gives?
Old Apr 5, 2011 | 07:33 PM
  #24
mothman52's Avatar
Unhappy
I did screw up a timing belt on my old 86 Stanza wagon. I got the belt part right but couldn't get the new idler to the proper tightness. The result was an early retirement for the Stanza....(sniff)
My vote is to find a good local mechanic that'll do it for a reasonable fee, unless you have the time, know-how & experience. Or can afford to send your car off to the pasture if the belt slips and your timing goes South....
Old Apr 6, 2011 | 07:11 PM
  #25
jimi's Avatar
I would do it myself, if not then I would go to a shop and stay clear of a dealer.
Old May 4, 2011 | 02:51 PM
  #26
Rougesvp's Avatar
Folks,
In you're in the DFW area, Mitsu Main Dealer in Irving ,TX. TB special 'til the end of August. All in for $465 + tax.
I'll see you there with 160k on mine!
Old May 18, 2011 | 06:32 PM
  #27
05Limited's Avatar
At 120k I had Cornerstone Mits in Wilmington MA do it for $450. Good guys....no problems after 25k miles...
Old May 19, 2011 | 12:36 AM
  #28
mvious's Avatar
Default Indy shop will need some tools for TB change
Nothing wrong with a good indy shop, but they'll need to make or buy 3 tools, one to get the crank pulley off, one to get the cam sprocket off (if they are doing the front seals), and one to torque the tensioner.
I just finished mine with 130K on my 2002 LTD, the belt was in excellent shape and probably could have gone a lot longer....
Good luck.
Old Aug 9, 2013 | 02:45 PM
  #29
logantanner's Avatar
Someone mentioned an inspection panel for checking the timing belt? Where do I find that and how do I access it? I've got a 2002 Limited with 145k miles. I've hot zero probs since buying it with 79k on it. It's def time for a timing belt and I am tight for money. Want to go the cheap route, but I understand the pushback about Monteros being a rare car that most mechanics have NO experience with. My biggest fear is that my local Mitsu dealership here in Colorado seems completely inept. It was a Dodge dealership that absorbed Mitsu. My experience with them thus far has been pretty sad. They know nothing.
Logan
Old Aug 9, 2013 | 08:21 PM
  #30
MXer746's Avatar
You could do it for a lot less yourself. It's really not that hard.
