Traction Control + ABS lights on after AC drain leak
Old Oct 4, 2022 | 08:45 PM
MAMontero04's Avatar
Default Traction Control + ABS lights on after AC drain leak
The AC drain on my 2004 Montero Limited backed up, causing water to drip into the passenger footwell. Shortly after this, the traction control and ABS lights turned on. I'm thinking a module shorted out? Everything else works, the car drives fine and the 4wd engages in all modes. Is the traction control built into the PCM/ECU or is it a separate module I can replace/repair? Any input is greatly appreciated. This Montero is new to me, in great condition otherwise so I am assuming the water ingress and sudden disabled traction control are NOT a coincidence.
I fixed the AC drain issue, so I'm comfortable replacing any electronics in the cabin at this point.
guangui
Feb 26, 2013 01:50 PM
elgrano
May 12, 2010 04:29 PM
tj90
Nov 25, 2009 07:22 PM
montero1
Feb 24, 2007 01:20 PM
Bearwater
Aug 22, 2005 12:22 AM
