tranny/coolant
Old Oct 15, 2007 | 01:24 PM
Killer's Avatar
Default tranny/coolant
i've got a 93 montero... sr... and i think it's leaking coolant...
anyone else ever have this problem? i can't get a picture but i sorta made a quick drawing...
Old Oct 15, 2007 | 05:10 PM
Default RE: tranny/coolant
Try a picture lol
Old Oct 15, 2007 | 06:17 PM
off roader's Avatar
Sorry I'm not clear on what you've drawn? In the left image, whats that large round circle for? Sounds like you have an engine coolant leak. Where is it coming from the front or rear of the engine? Near the top or bottom of the engine? Radiator?
Old Oct 15, 2007 | 06:41 PM
Green = Coolant
Red = Transmission
Old Oct 15, 2007 | 06:53 PM
jpmontero98's Avatar
[quote]ORIGINAL: Killer
you need to use a different image code(click "image")
Old Oct 16, 2007 | 10:58 PM
mxmikie's Avatar
looks like the drain plug in the rad is leaking
Old Oct 18, 2007 | 04:56 PM
Killer's Avatar
i'm gonna get a picture when i can!!! it's kinda rainy here today and i just found my memory cards... so it'll be up tomorrow hopefully...
the circular drawing would be if you were looking at the tranny head on... like taking the rest of the car away......
the other is if you are flat on you're back....
but i'll get an actual picture when i can!!!
anyways, i know it's not tranny fluid.. it's coolant.. FOR SURE... it is on the right side of my tranny though near the front of the vehicle... i just can not seem to find a leak... and it looks like it's coming from the tranny.. though the tranny has it's own lines that run fluid to a "mini" radiator to cool the tranny fluid.....
Old Oct 18, 2007 | 05:09 PM
Killer's Avatar
the fluid is coming from the front of the tranny.... say you are under the vehicle on your back... feet at the rear of vehicle.. head at the front..
here is another "paintchop" now i can't draw it, but on the right side of the transmission where it bolts to whatever, there is some sort of "opening" no not a hole or gap. it's apparently made this way... the metal is a good inch or two apart.. and this is where it appears to be coming from...
Old Oct 18, 2007 | 05:12 PM
off roader's Avatar
OK. I suspect it's either...
A) a leaking rubber hose that goes between the block and the firewall (to your heater core in your dash). You repair this by simply replacing the hoses. Takes probably 20 minutes tops. Make sure you run your engine to get all the excess air out of your cooling system after you replace them.
or
B) your O-ring to your water pump has gone bad and it's now leaking water into the valley between the cylinders and is pouring out the back of the engine which makes it look like it's coming from the transmission. This problem requires you to R&R your water pump to replace the O-ring.
There arent' too many other things that go bad w/ the cooling system except maybe your radiator needing a rodding but that's only an issue if you don't use distilled water (PURE water) w/ your coolant.
HTH.
Old Oct 18, 2007 | 05:13 PM
What color is it?
