tranny dip stick has a drop of fluild on it....
Old Nov 11, 2019 | 08:15 AM
albertinhouston's Avatar
Default tranny dip stick has a drop of fluild on it....
This is a recent purchase for me. I didn't let it get this way hahahaha
As the title says... the fluid is barley touching the dip stick. I'm headed to the dealer after today to pick up some SPIII tranny fluid. How many quarts would be a good guess to buy based on the dip stick.
What made me look for this is the C/D lock light started blinking do the first thing I checked was this.
Old Nov 11, 2019 | 12:14 PM
disregard I bought 5 qts at my local dealer. $7.50 a qt. same as if I would have gotten it on amazon.
Old Nov 11, 2019 | 08:49 PM
I would venture to guess you'd need at least 2 quarts if you measured fluid with engine running. If not - a lot more...
Old Nov 11, 2019 | 09:10 PM
Yes it was 2qts. But it didnt fix the blinking light. But more importantly. It now goes into gear every time
Old Nov 12, 2019 | 01:42 PM
Glad your tranny behaves better now. The flashing C/D lock light is more likely related to a transfer case. There are a number of input/output and other sensors on the transfer case. Any one of those could cause the flashing light. With some work and persistence, it's possible to figure out which one is causing the problem and replace it or fix wiring.
skipperx
Apr 17, 2013 08:56 PM
hershman
Aug 13, 2010 03:10 PM
18chris1289
Apr 12, 2009 09:16 PM
suz
Jun 3, 2008 08:16 AM
racerx55
1st Generation
Apr 15, 2007 08:47 AM
