transmission 02 montero spt
Old Jul 16, 2006 | 03:18 AM
Roverguy's Avatar
Default transmission 02 montero spt
My wife's montero has decided it prefers 2nd gear. The "N" indicator light flashs and the trans will not respond to manual selection of the gear shift, (unless, of course, I choose other than foward), the check engine light is also on, I haven't hade a chance to get the stored codes retrieved yet. Any suggestions? ?
Old Jul 16, 2006 | 06:21 AM
off roader's Avatar
Default RE: transmission 02 montero spt
Um... get the codes first.
Current mileage?
Have you changed your tranny fluid recently? If so, did you use mitsu tranny compatible fluid?
Old Jul 16, 2006 | 03:51 PM
Roverguy's Avatar
Milage is about 65000 tranny fluid was changed at about 50000, at a dealership. I'm hoping that's not an issue it seems to me to be more of an electrical thing.
Old Jul 17, 2006 | 01:49 PM
mike in nc's Avatar
I have a 2000 that does the same thing, will be going down the road and it will go in 3rd in my case. The N light will flash and the "check engine light will come on. The dealer has had it several times, but to no avail. If I stop and let it cool off it is ok for a little while, but once the check engine light is on, it has to be reset. I started a message on here myself about this several months ago. I hope someone has the answer. here is my post https://mitsubishiforum.com/m_69865/tm.htm
Old Jul 24, 2006 | 04:39 PM
Roverguy's Avatar
I finally broke down and agreed w/ Mrs. Roverguy, and we (she) took it to the dealer. They diagnosed a bad "fail safe switch" as the problem. Three days later, when the switch arrived, all seems well. Mrs. Roverguy is a lot happier too.
Old Jul 26, 2006 | 10:36 PM
mike in nc's Avatar
Roverguy, curious if your problem is still fixed. I am still having problems with the same thing
CALEB
Oct 14, 2009 10:19 PM
zonarosso
Oct 9, 2009 11:24 AM
lovinmrv
Jan 10, 2009 02:59 PM
jpardinas
Oct 19, 2005 11:30 AM
monterojay
Jun 14, 2005 09:31 PM
