Transmission Problem
Old Jan 18, 2014 | 03:57 PM
bjartmar's Avatar
Question Transmission Problem
Hi.
I have Mitsubishi Montero 2003 Limited - 3,8 - 6 cyl - 81.000 Miles.
The transmission is acting really weird.
It's like I have no control of what 'gear' it uses. (Park/Reverse/Neutral/Drive)
When I switch between 'gears' I finally get it to Drive and it works...
...but it's very "heavy" driving.
Please, help!
Old Jan 18, 2014 | 08:37 PM
Akzle's Avatar
take it to an auto trans specialist. this isn't the kind of thing that can be fixed on the internet.
also. don't buy autos in future.
Old Jan 18, 2014 | 08:46 PM
navidbe's Avatar
I'm pretty sure auto is the only option in the US and Canada. i bought my 03 limited brand new and had no option for a manual.
Old Jan 19, 2014 | 01:41 AM
Akzle's Avatar
it would be sh't if it was. Im sure you could request it.
Oh well. Gotta keep someone paid eh.
Old Jan 19, 2014 | 07:06 AM
bjartmar's Avatar
Exclamation
I didn't really expect to get this fixed over the internet. I called AT Specialist and they said:
"This is a common problem for Montero... We have given up trying to fix those AT's... This is the planet gear... We can import a used AT for $5000USD and install it for another $1700USD... It's not just plug&play there have to be specialised configuration after installation".
The problem is... I'm located in Europe, Iceland where there are not so many Monteros. We have high import taxes on spare-parts and shipping fee is high.
I thought if this was a common problem, you would know. I just wanted a confirmation the AT needs replacement and ask if it needs any specialized configuration after installation.
Old Jan 19, 2014 | 12:39 PM
Akzle's Avatar
being 2003 its likely a computer needs playing with. Thats 'specialist config'
Swapping a trans itself is a very easy job.
If a pro has diagnosed planet gear, id go with that.
Being auto, its probably too complicated to swap out actual gears.
Old Jan 19, 2014 | 04:30 PM
navidbe's Avatar
i looked into rebuilding it, and its not an easy job what so ever! these AT are so sophisticated not everyone will be able to do it, and there is a high chance of them messing it up. and I'm sure you can find a used tranny for cheaper, i just picked mine up in canada for 1800 usd. and it is CLEAN.
Old Jan 19, 2014 | 05:52 PM
bjartmar's Avatar
Thanks for the answer.
I don't really think I'm going to rebuild this one. Did you replace it by yourself?
Did you need specialized configurations after installation? Computer work?
Thanks for answer. I think I'll try to find a new one to swap out.
Do you know if there are some other vehicles that has the same AT?
Where can I find the name of my AT?
( Cars VIN: JA4NW61S63J042608 )
Old Jan 22, 2014 | 05:03 PM
navidbe's Avatar
[QUOTE=bjartmar;298692]Thanks for the answer.
well I'm in the middle of getting it swapped out right now, ill let you know this weekend when its finished.
Old Jan 23, 2014 | 09:55 AM
bjartmar's Avatar
[QUOTE=navidbe;298760]
Nice, that would be great to have some insight on the swap and how things work out. Good luck on your swap.
